MadRatSuun Posted June 2, 2022 Report Share Posted June 2, 2022 Howdy gang, new owner of a ‘86 d21. She has 140k on her and currently doesn’t start i just did spark plugs, spark plug wires, changed oil, coolant flush and drained gas tank and added fresh gas, battery and she won’t start i was told to beware of the whole 1986.5 thing and to confirm the wiring goes to the correct port in the distributor cap.. so do I consider it a 85 or a 87 when ordering parts? It had a Weber carburetor in it and tbh I’ve never owned a car with a carburetor so I’m not sure if it’s a rebuild issue or is it the fuel pump but seems like a fuel issue but I am not sure any help or suggestions appreciated team ratsun 😎🏴☠️ Quote Link to comment
datzenmike Posted June 2, 2022 Report Share Posted June 2, 2022 The earlier 720 ended production and the later D21 Hardbody began about halfway through the '86 model year. Better look for the build date on the door jam. Bet it's an '86 720 which is easy to swap a Weber onto. You could look at the engine tag riveted to the passenger side inner fender just under the hood hinge. Does it say 720 in the upper right? What engine and transmission is listed The D21 is all fuel injected with a crank angle sensor and would be a nightmare to convert to carburetor use. Quote Link to comment
MadRatSuun Posted June 2, 2022 Author Report Share Posted June 2, 2022 God damn I’m retarded and didn’t post the photo but it looks like a different tag than the one you posted Chassis #JN6ND16S4GWD12388 model KNLGD21FEU3 engine z24 (1) 2389 trans axle FS571C HF37 plant W Quote Link to comment
datzenmike Posted June 2, 2022 Report Share Posted June 2, 2022 9 minutes ago, MadRatSuun said: Chassis #JN6ND16S4GWD12388 model KNLG D21 FEU3 engine z24 (1) 2389 Definitely a D21 Hardbody. So we have confirmed the truck model and year from the VIN as an '86 with 24i engine. (the small i after the Z24 signifies throttle body injection) Now you said it has a carburetor so either an earlier 720 intake and carburetor, distributor and drive spindle and a low pressure fuel pump was put on or an entire Z24 from a 720 was swapped in. You might confirm the engine size (if swapped could be a Z20 or Z22) by looking between the two pair of exhaust pipes at the flat boss on the top edge of the engine block directly below the #2 and #3 spark plugs... 1 Quote Link to comment
MadRatSuun Posted June 3, 2022 Author Report Share Posted June 3, 2022 It’s a z24 i just double checked the spark plug wires go to the correct position in the distributor cap recent so hinges I’ve done since I got her oil change / oil filter fuel filter / drained gas tank added a fresh gallon new battery spark plugs and wires power steering fluid drained / flushed coolant waiting to do brake fluid til she runs after I did it he sparks I tried starting it and she cranked and then back fired so is it the fuel system? im working on taking down the air filter to tweak the carburetor it has the Weber carburetor and I know to adjust the ratio screw (very carefully) as well as the idle screw also carefully any suggestions? ’86 Nissan d21 z24 engine 2wd 5 spd only has 140k on the chassis so she has to have life still haha Im so thankful You all are here haha glad to be a part of the RatSun gang 😎🤙🏾🏴☠️ Quote Link to comment
datzenmike Posted June 3, 2022 Report Share Posted June 3, 2022 Well a backfire is probably normal after sitting. With the air filter housing top off, is the choke on? This Not this, or partly closed Quote Link to comment
MadRatSuun Posted June 3, 2022 Author Report Share Posted June 3, 2022 It looks like it is open Quote Link to comment
MadRatSuun Posted June 3, 2022 Author Report Share Posted June 3, 2022 My goal is to get her running by 7/20/2022 lol but in no rush just eager to drive it long fan of Nissan and my Grandmum had a old 510 n I always caught my eye Quote Link to comment
datzenmike Posted June 3, 2022 Report Share Posted June 3, 2022 1 hour ago, MadRatSuun said: It looks like it is open Pump the gas pedal once while watching the carburetor. The choke should snap closed if it has an electric choke. Perhaps it has a manual choke? Try pumping the gas 3-4 more times then try to start. Quote Link to comment
MadRatSuun Posted June 3, 2022 Author Report Share Posted June 3, 2022 Hmm so I took the air filter off and cleaned the Weber carburetor from the top lightly or as good as I could for the first time tweaking a carburetor ever i sprayed a bit of starter fluid and then a combo of gas and starter fluid.. it cranked and I got excited so I tried the same thing a bit more (3/4 times max) then it wouldn’t even crank? battery still turns lights and stereo on etc but no crank starter? Or fuel issue? Quote Link to comment
MadRatSuun Posted June 3, 2022 Author Report Share Posted June 3, 2022 The butterfly is black and I cleaned it back to the gold ish color it comes as new But the butterfly is so crusty and has a hard time moving from open to close Quote Link to comment
datzenmike Posted June 3, 2022 Report Share Posted June 3, 2022 Battery may need recharging. Quote Link to comment
MadRatSuun Posted June 3, 2022 Author Report Share Posted June 3, 2022 Just bought a brand new battery a week or two ago i already reviewed the battery issue thread and plan to look at that tomorrow also Quote Link to comment
MadRatSuun Posted June 4, 2022 Author Report Share Posted June 4, 2022 So I cleaned the carburetor but I think it may need to be cleaned more thoroughly or rebuilt I tried starting it from the carb but now it won’t crank. I got a new battery less than 2 weeks ago so something must be pulling from it i basically am thinking I need to go through it with a multi meter and see where it is drawing I need to find out how to save the battery when she is sitting and not running Quote Link to comment
MadRatSuun Posted June 7, 2022 Author Report Share Posted June 7, 2022 Pretty sure it needs a new carburetor rebuilt or a new one the butterfly shoot doesn’t react when I pull the throttle body I can hear fuel getting sent into it when I do pull the throttle body it cranked and back fired the day I changed sparks and wires so…. I think it’s the carburetor I tried resetting the idle pin as well as resetting the ratio mixture screw but the butterfly is stuck open the carburetor clearly has had a lot of backfires as it is covered in carbon /grime ive never dealt with a carburetor But I’m getting more comfortable (ish) so I think carburetor/ fuel pump / electrical any suggestions are fully appreciated MadRatSuun 😎👍🏾🏴☠️ Quote Link to comment
datzenmike Posted June 7, 2022 Report Share Posted June 7, 2022 On 6/4/2022 at 10:44 AM, MadRatSuun said: I tried starting it from the carb but now it won’t crank. I got a new battery less than 2 weeks ago so something must be pulling from it Starter does not turn the engine??? Battery low on charge or being new perhaps it's no good. Recharge the battery or have it recharged. If you have another vehicle and booster cables, connect it up and let the other car idle for 1/2 hour. Quote Link to comment
MadRatSuun Posted June 13, 2022 Author Report Share Posted June 13, 2022 720 masters please check in new battery new spark plugs and wires, drained gas tank and added fresh gallon, replaced all fuses and main relays, I can hear the fuel tank humming when I turn the key to run, also when I pull the throttle body on the Weber carburetor and also hear fuel being squirted into carburetor, flushed coolant, now I get no crank just a click so would the next order of operations be starter? carbuerator rebuild? fuel pump? Quote Link to comment
Stoffregen Motorsports Posted June 13, 2022 Report Share Posted June 13, 2022 Ground from battery to engine block? Have you checked that? How is the power cable on the bot side of the battery? If both cables are good, with good connections, the reasons for no-crank are limited. Most likely bad starter or starter solenoid. We are all assuming that you've tried jumping the battery from another car or a charger. I know you say "new battery" but I have a basic rule - assume nothing. Gotta crank before it can run, so check that off the list first. Quote Link to comment
