NicktheMillwright Posted April 19, 2022 Report Share Posted April 19, 2022 Good afternoon everyone Im trying to figure out what sort of manual transmission fluid I can put into my 1985 720 Z24. From what I've gathered, the following are viable; All GL-4 BTW, and this is for the climate of British Columbia, Canada - Redline MT90 75w90 - ACDelco Synchromesh with Friction modifiers (Can't seem to find any locally) -Sta-Lube 85w90 (No one carries this it seems) Are there other options? 2 of the 3 on this list im having a hell of a time tracking down and MT99 75w90 seems like it may be too thin on its own. Some insight is appreciated Nick Quote Link to comment
datzenmike Posted April 20, 2022 Report Share Posted April 20, 2022 Last time I tried to find the Delco it wasn't available. Try Amazon? US and Can use different GM part numbers. The real stuff is thin and amber/orange color. I asked a GM dealer what the new Corvette was using in the manuals and he said it was a pink colored ATF. Red Line and Royal Purple and several others are probably the same base stock but with different color additives. It's thin and it works wonders but can leak past the old output seals. Shifts faster, shifts much easier when cold and down shifts way better. It's not cheap though. Otherwise GL-4 80 or 90w is fine. 1 Quote Link to comment
Thomas Perkins Posted April 22, 2022 Report Share Posted April 22, 2022 This is what I use in my 85 Nissan 720 4x4. - Redline MT90 75w90. I got it from Ebay , 2 PK for 35.90 and a 10 dollar pump from Harbor freight...Just checked it the other day and is full,no leaks and shifts so smooth.. 1 Quote Link to comment
NicktheMillwright Posted April 22, 2022 Author Report Share Posted April 22, 2022 Ended up running MT90 75w90. So far no leaks but have purchased a output shaft seal just in case. I plan to replace it in the near future. I had another question regarding the transmission. Mine seems to fight me a little to get into gear. It's not consistent but happens maybe 50% of the time regardless of speed. Is that just a characteristic of this transmission or should I strip it down and inspect? Quote Link to comment
datzenmike Posted April 22, 2022 Report Share Posted April 22, 2022 Check your hydraulic clutch fluid. Any air trapped in the hydraulics will reduce clutch disengagement preventing the clutch disc from fully disconnecting from the engine. The synchronizer rings are overwhelmed and shifting is harder. Try shifting into reverse, does it grind??? 1 Quote Link to comment
NicktheMillwright Posted April 22, 2022 Author Report Share Posted April 22, 2022 It will on occasion. In my 1 week or so of ownership it has 3 times. I'll check/replace it outright to eliminate that possibility 1 Quote Link to comment
datzenmike Posted April 22, 2022 Report Share Posted April 22, 2022 No, no, no. Replace what? This is replacing a tire that only needs air. See if it needs fluid or bleeding. Original equipment parts are always better that crappy made in China replacements. 1 Quote Link to comment
