Thomas Perkins Posted November 13, 2021 Report Share Posted November 13, 2021 (edited) Hi ya'll.Here are some pics of my 32/36 Redline Weber that I cleaned up and replaced the gaskets.Also my newly painted Brake booster,new Egr valve and new exhaust manifold.Where the old gaskets are heavy stained is where it was leaking,in the front and back,same as last time..I also did this 3 years ago.Also put a new air filter on.On the nut that holds down the carb. closest to the left by the firewall,it's a tight fit,I used a 11 mm box end wrench which made it easier.The same nut size is across from it,the other two I used a 12 mm open end wrench.My little plastic fuel filter was still good.Also my new A.C. compressor.See my idle cut off solenoid...I used brake cleaner and a 3M scrub pad. Edited November 13, 2021 by Thomas Perkins 1 Quote Link to comment
Stoffregen Motorsports Posted November 14, 2021 Report Share Posted November 14, 2021 Nice work. 1 Quote Link to comment
