SHADY280 Posted December 6, 2008 Report Share Posted December 6, 2008 so as it seems to have turned out i purchased a 6 bolt 200mm flywheel. id like to get 100 bux for it so i break even. in good shape, even is clean, could use a light machining to get the surface perfect for a new clutch. lemme know ill ship, and its only 10 lbs or so. great for a racer. it somehow fits a 225 clutch disc, but needs the 200mm pp. unless someone has a 200 centerforce df pp i could get. Link to comment
SHADY280 Posted December 6, 2008 Author Report Share Posted December 6, 2008 heres a pic of it and with a 225mm disc on it Link to comment
heirfaus Posted December 8, 2008 Report Share Posted December 8, 2008 I just wanted you to know that if a 225mm disks fits a flywheel........then it's a 225mm flywheel:rolleyes: Link to comment
hang_510 Posted December 8, 2008 Report Share Posted December 8, 2008 intrested... measure the friction plate surface area, that is the only way to know if its 200mm or 225mm. Link to comment
datzenmike Posted December 8, 2008 Report Share Posted December 8, 2008 Looks like there's room for a 240mm disc to fit too. The pressure plate that fits the dowels and bolt pattern determines the size it's for. I think the three Nissan PP bolt patterns are different. I know the 225mm and the 240mm are. Measure across the center of the flywheel from one PP bolt hole to the other. This will tell you if it for a 225mm or a 240mm. A 225mm PP is 270mm bolt to bolt. A 240mm PP is 280mm bolt to bolt. Link to comment
SHADY280 Posted December 9, 2008 Author Report Share Posted December 9, 2008 the 225 pp is too big therefore fitting a 200mm!! that why im selling it as 200mm. i just dont have a dang clue as to why the 225 disc fits and the pp dont, theres even a thread on it. i called the po back, he just laughed, and said, yours now! Link to comment
hang_510 Posted December 9, 2008 Report Share Posted December 9, 2008 intrested... pix and ship est to 93003 :D Link to comment
SHADY280 Posted December 9, 2008 Author Report Share Posted December 9, 2008 what other pix you want? heres the thread linky http://forum.ratsun.net/showthread.php?t=8069&page=2 itll be 24 bux to ship to you. thats 10-12 bus. days. by regular mail guaranted Link to comment
datsunaholic Posted December 10, 2008 Report Share Posted December 10, 2008 Have you actually tried a 200mm pressure plate to see if it'd fit? Worst case scenario it won't even fit a Datsun. Or it only fits a specialized aftermarket pp and clutch setup. The guide pin holes in the center and the ring gear teeth look a little odd to me. Link to comment
SHADY280 Posted December 10, 2008 Author Report Share Posted December 10, 2008 i dont have a 200mm, kinda sucks, i cant find one around, kinda rare here. the holes in the center may be to lighten it even more, it has been balanced to run on a scca roadrace car (510). car apparently reved to 9000 rpm!! Link to comment
hang_510 Posted December 10, 2008 Report Share Posted December 10, 2008 what other pix you want? none, just cant view them from work :cursing: i should be able to check them out tonight and ill get back to you! Link to comment
heirfaus Posted December 11, 2008 Report Share Posted December 11, 2008 i dont have a 200mm, kinda sucks, i cant find one around, kinda rare here. the holes in the center may be to lighten it even more, it has been balanced to run on a scca roadrace car (510). car apparently reved to 9000 rpm!! I have a nib 200 pp. I'll take some measurements tomorrow... Link to comment
heirfaus Posted December 11, 2008 Report Share Posted December 11, 2008 (edited) the holes in the center may be to lighten it even more, Holes that far in aren't going to help in the lightening process, they aren't far enough out to make a difference. As far as I understand it, those are custom dowel holes. Some cars have them, most don't. NONE of the L motors came that way, but I have seen a couple of custom jobs. Supposedly you make the exact same hole in the flywheel and crank and insert dowels in the crank. This is supposed to add strength to the flywheel mounting so that it is not only held on be the threads of the bolts. Official Nissan 200mm pressure plate This is how I measured it The center to center measurement for the mounting holes is 240mm Edited December 11, 2008 by heirfaus Link to comment
hang_510 Posted December 11, 2008 Report Share Posted December 11, 2008 thanx heirfaus! that is the PP i would need it to mate to, w/o mods. if the FW matches it, ill send the $$$$$$$$$ :D Link to comment
SHADY280 Posted December 12, 2008 Author Report Share Posted December 12, 2008 kk will do some measuring, its gonna smow friday, so my dd 280zx doesnt move. i get to borrow rides, so it may be as late as monday, so hang with me!! if i can ill try and get to my shop sooner to not keep the answer waiting. thanks a mill heirfaus Link to comment
