grannyknot Posted May 19, 2021 Report Share Posted May 19, 2021 These two pink hoses come from the top of the vapour tank on a 1973 510, but where do the go to? The car was in boxes when I got it so I'm sure I'm missing stuff. Thanks, Quote Link to comment
datzenmike Posted May 19, 2021 Report Share Posted May 19, 2021 Show the vapor separator. Does it have 3 outlets? 2 on the top and one in the center bottom??? Quote Link to comment
grannyknot Posted May 20, 2021 Author Report Share Posted May 20, 2021 Yes that's it exactly. Quote Link to comment
datzenmike Posted May 20, 2021 Report Share Posted May 20, 2021 The center bottom hose goes to the far left (as viewed from the rear) top of the fuel tank. Of the two on the top of the vapor separator... The one farthest to the right goes to the top of the filler neck. There is a 'T' in it, and another hose, probably larger, joins it from the top right of the tank. The second hose, appears to also be slightly closer to the back seat than the other, is the tank vent going to the front of the car to the flow guide valve mounted on the diver's side strut tower. 1 Quote Link to comment
grannyknot Posted May 20, 2021 Author Report Share Posted May 20, 2021 19 hours ago, datzenmike said: is the tank vent going to the front of the car to the flow guide valve mounted on the diver's side strut tower. No that has all been removed as I'm using a KA24DE. Thanks for the info. Quote Link to comment
datzenmike Posted May 20, 2021 Report Share Posted May 20, 2021 Then it would go into the charcoal canister. The DE used them. Quote Link to comment
