zetabird Posted April 16, 2021 Report Share Posted April 16, 2021 been doing alittle digging and was just looking for a solid answer, im putting the intake and exhaust back on and need the torque spec and sequence. from what ive read it should be about 10-14 ft/lbs is that right? Quote Link to comment
datzenmike Posted April 16, 2021 Report Share Posted April 16, 2021 I have the bolts/studs for the L series manifolds as 9-12 ft lbs. These are aluminum heads and will strip easily. Use the lowest number you can. Don't know if there is a sequence for the A series, the L series does not. I don't think it would matter. Quote Link to comment
zetabird Posted April 16, 2021 Author Report Share Posted April 16, 2021 alright, will do i was just going to do center out tightening them,. never messed with anything that uses these yoke washer before though. 1 Quote Link to comment
datzenmike Posted April 16, 2021 Report Share Posted April 16, 2021 Sounds good. Quote Link to comment
zetabird Posted June 28, 2021 Author Report Share Posted June 28, 2021 another question instead of cloggin it up with a new thread, the fuel inlet fitting on the carb is a bit bent and buggered up from a previous "rebuild". do you know if its a standered pipe thread or is it some type of metric. the shop i work at has boxes of AN fittings and enough scraps of line from the racecars that i can build a whole new fuel system with scraps for free. Quote Link to comment
datzenmike Posted June 28, 2021 Report Share Posted June 28, 2021 Is it a banjo fitting on the A series carburetor? Quote Link to comment
zetabird Posted June 28, 2021 Author Report Share Posted June 28, 2021 Nope its a 90 degree hose barb that had a small meah screen in it but that was smashed when i took it off it looks like pipe thread to me but i dont k ow if japan would have used a diffrent standard than we did on that Quote Link to comment
datzenmike Posted June 28, 2021 Report Share Posted June 28, 2021 Is there a small crush gasket? If so probably a metric bolt thread. The gasket does the sealing not the threads. Quote Link to comment
zetabird Posted June 28, 2021 Author Report Share Posted June 28, 2021 (edited) Nope no gasket thats why i thought it was pipe thread. ive got it back on without the filter in it. It was crushed. Edited June 29, 2021 by zetabird i cant speel Quote Link to comment
