Beowulf 19 Posted October 7, 2020 Report Share Posted October 7, 2020 Thought I’d ask for pointers on getting the cab off the frame. Any special do’s or don’ts? Got the cab bolts out with out breaking any, although the two front will need replacing. Grade 8 or 10 as replacements? Haven’t found a place for replacement bushing. TIA Quote Link to post
datzenmike 39,334 Posted October 7, 2020 Report Share Posted October 7, 2020 On a 720/D21 Hardbody and anything newer you can disconnect the steering column from the steering box and lift it away but for the 620/521/520, you'll have to take the bed and the steering wheel off and slide the cab up and back off the column. I've done this on a 620. The bolts don't have to be anything special. Quote Link to post
Beowulf 19 Posted October 10, 2020 Author Report Share Posted October 10, 2020 Guessing I’ll remove the doors to lighten it. All ready gutted the interior, guessing 4 guys should be able to lift the cab off. thanks for the info Quote Link to post
datzenmike 39,334 Posted October 10, 2020 Report Share Posted October 10, 2020 I did it with two teenagers and myself so.... yes Quote Link to post
