Goosie_the_xiii Posted July 9, 2020 Report Share Posted July 9, 2020 Just wanted to see what turbo manifold people are using for their KA-T setup. I am debating going down that route. I already have the KA in my 620. If you have a KA-T did you have to do any other fabrications to make it fit? I have been searching the forums to see any information or photos of turbo setups but there are no clear shots that I have found. If possible, looking for a direct drop in with little to no fabrication needed to make it fit. Quote Link to comment
breezenahan Posted July 9, 2020 Report Share Posted July 9, 2020 I am running KA-T in my s13 and working on SR20DET in my 620, from what I have heard you need to have a top mount manifold for the SR and I imagine the KA is the same. I used a CXRacing manifold in my s13, no complaints so far but it is cheap so be wary. What would be a major concern of mine is downpipe/exhaust/wastegate clearance. It gets very busy right around where the steering column/box is supposed to be, maybe running something with an internal wastegate is the only option, which would preclude you from using the CXracing manifold without modification of some kind. Quote Link to comment
5t341tH Posted July 11, 2020 Report Share Posted July 11, 2020 On 7/9/2020 at 12:04 PM, breezenahan said: I am running KA-T in my s13 and working on SR20DET in my 620, from what I have heard you need to have a top mount manifold for the SR and I imagine the KA is the same. I used a CXRacing manifold in my s13, no complaints so far but it is cheap so be wary. What would be a major concern of mine is downpipe/exhaust/wastegate clearance. It gets very busy right around where the steering column/box is supposed to be, maybe running something with an internal wastegate is the only option, which would preclude you from using the CXracing manifold without modification of some kind. not true. I'm running bottom mount on mine with a gtx2860 Quote Link to comment
Goosie_the_xiii Posted July 12, 2020 Author Report Share Posted July 12, 2020 On 7/10/2020 at 9:59 PM, 5t341tH said: not true. I'm running bottom mount on mine with a gtx2860 What manifold are you running? Quote Link to comment
5t341tH Posted July 13, 2020 Report Share Posted July 13, 2020 I'm pretty sure stock manifold would work too. But I am using a Tomei manifold. Mine is SR20 though Quote Link to comment
