high winder Posted June 12, 2020 Report Share Posted June 12, 2020 on my 5spd i have two electrical plug ins. one is for the backup lights but i have no idea what the other one is for and my manual doesn't show it either. anyone have any idea what its for? Quote Link to comment
Draker Posted June 12, 2020 Report Share Posted June 12, 2020 Neutral safety switch or emissions switch for the carb. Quote Link to comment
datzenmike Posted June 13, 2020 Report Share Posted June 13, 2020 Top gear or neutral. Used only for emissions equipment. Quote Link to comment
high winder Posted June 13, 2020 Author Report Share Posted June 13, 2020 Thanks... figured might be something like that Quote Link to comment
datzenmike Posted June 13, 2020 Report Share Posted June 13, 2020 On some later trucks these switches plus a clutch switch and an engine vacuum switch was used to turn the idle cut solenoid off during deceleration. If you think about it, the carburetor is at idle when your foot is off the pedal. That idle gas is not needed to keep the car going as vehicle speed does that. As long as you are in gear, with the clutch pedal up and engine vacuum above a set amount then the idle cut is off. Saves gas too!!!. Quote Link to comment
