TheBirdistheWord Posted June 11, 2020 Report Share Posted June 11, 2020 After spirited driving It appears my rear toe has maxed outward on both side of vehicle. Can see the slip marks made by the washer. When I threw a buddies toe brackets on the car it it tells a different story. The measurement is confusing to me, it suggests theyre actually slightly toed in. I was helping the alignment tech adjust the rear on the rack and we set it slightly out it's possible the marks on the bracket are old and I just don't remember it. But that doesn't explain why they're measuring toed in. I've considered welding them in place after alignment but I was under impression these brackets were the solution to the old slot and weld technique on stock rear Xmember brackets. There's not much meat on the bottom adjustment slot so I'd like to avoid this approach. Anyone know what gives? How to keep in place with supplied hardware? Quote Link to comment
Draker Posted June 11, 2020 Report Share Posted June 11, 2020 I haven’t really been too hard on mine, but they don’t move. Put a fair amount of miles on them though. I’m not impressed with the amount of adjustment with those brackets. Maybe the datsport offering is better. 1 Quote Link to comment
TheBirdistheWord Posted June 14, 2020 Author Report Share Posted June 14, 2020 On 6/11/2020 at 2:19 PM, Draker said: I haven’t really been too hard on mine, but they don’t move. Put a fair amount of miles on them though. I’m not impressed with the amount of adjustment with those brackets. Maybe the datsport offering is better. I was under the impression it was the same design. Probably just big O quality alignment to blame. After I install a fewore things I'll be bringing it to Sprint Motorsports In San Jose and see what they suggest. Quote Link to comment
