Kurt Posted April 26, 2020 Report Share Posted April 26, 2020 When I connect my battery, the warning lights come on the instrument panel; whether key is in ignition or not. When I start the car, the lights go off per normal. Key turns freely and problem arose instantly and not over time. Do I need to change the entire switch? Quote Link to comment
afracer Posted April 26, 2020 Report Share Posted April 26, 2020 Can't hurt, they're not expensive Quote Link to comment
80datson Posted April 29, 2020 Report Share Posted April 29, 2020 On 4/26/2020 at 2:51 PM, Kurt said: When I connect my battery, the warning lights come on the instrument panel; whether key is in ignition or not. When I start the car, the lights go off per normal. Key turns freely and problem arose instantly and not over time. Do I need to change the entire switch? could be your ignition, maybe try cleaning off the connections? Quote Link to comment
pdp8 Posted May 10, 2020 Report Share Posted May 10, 2020 You don't need an ignition lock assembly, but indeed for under $20 you might as well throw a new switch assembly on the back and see if this fixes things. Quote Link to comment
