Ignition switch gremlin
Kurt
When I connect my battery, the warning lights come on the instrument panel; whether key is in ignition or not.  When I start the car, the lights go off per normal. Key turns freely and problem arose instantly and not over time.  Do I need to change the entire switch?
  • Replies 3
could be your ignition, maybe try cleaning off the connections?
You don't need an ignition lock assembly, but indeed for under $20 you might as well throw a new switch assembly on the back and see if this fixes things.
