transmission mounted offset from center
raisehellpraisedale3
I got a 1981 datsun 720 5 speed that i just swapped the tranny on and the tranny is mounted a couple inches too far to the right. the tranny mount is bolted into the crossmember but is tilted a bit. tried using a prybar to move it back over a bit but it settles back into the same position it was in once theres no more pressure anyone know any quick solutions for that?
  • Replies 3
Is this your SD22 diesel engine?
What do you engine mounts look like?
Edited by wayno
