Daniel Gragg Posted October 16, 2019 Report Share Posted October 16, 2019 Have a friend with brand new weber 32 36 in box but it's for a jeep 158ci.could I use it on a z24 engine and if so what parts do I need to get if any besides the proper adapter plate. My friend is selling it to me for 50 dollars 2 Quote Link to comment
datzenmike Posted October 16, 2019 Report Share Posted October 16, 2019 I would confirm that it's a genuine Weber and not a POS Chinese knock off. Where did he get it from? Because a good one is about $300 for the kit with adapter, gaskets and air filter. A 32/36 is an excellent size, if jetted correctly, which should be close. The Z24 is 148cu.in.. 2 Quote Link to comment
Charlie69 Posted October 17, 2019 Report Share Posted October 17, 2019 If it is an old one then $50 is OK. If it is a new one it is a great price. But like mike said if it is a genuine Weber it will have made in Spain and Weber on the carb. The Chinese knock offs do not have either on it. Weber Idetification Video 1 Quote Link to comment
Daniel Gragg Posted October 17, 2019 Author Report Share Posted October 17, 2019 Thanks for the info. I just saw the carb for the first time today. Had to go to work before I could authenticate it. When he said new in box I thought he meant a redline box,but it was just in a generic box. It's just the carb and nothing else. Beginning to have second thoughts before buying. I think I would need to buy an air filter kit(40), adapter plate(40), and a throttle adapter (30), and I am sure a few other parts too. That adds up to around 150. 2 Quote Link to comment
Charlie69 Posted October 18, 2019 Report Share Posted October 18, 2019 Genaric box it is probably a Chinese knock off. Still worth looking at it though. If it is not a Weber I would not buy it. 1 Quote Link to comment
Daniel Gragg Posted October 20, 2019 Author Report Share Posted October 20, 2019 I see on you tube were some people hook up almost all the vaccum lines when installing a Weber carb, but others remove everything except the brake,advance and fuel canister vaccum lines. Any thoughts on this . . 1 Quote Link to comment
datzenmike Posted October 20, 2019 Report Share Posted October 20, 2019 All the Weber has is the ported vacuum advance for the distributor so the ported vacuum for the EGR isn't there so no EGR which isn't a hardship. The vacuum advance can be also used to signal the canister to purge. If you drive in colder climate in the winter you should modify the stock air cleaner to fit the Weber. This will allow you to keep and use the ATC (air temperature control) in the snorkel. This mixes cold air from in front of the rad with hot air warmed by the exhaust manifold. The air filter has a sensor that controls the vacuum operated motor in the snorkel and regulates the air entering the engine to around 100F. At -10F the engine thinks it's a summer day and drives like it. This also prevents carburetor icing at near freezing. 1 Quote Link to comment
