GarciaG Posted August 7, 2019 Report Share Posted August 7, 2019 im in the process of purchasing a 610 1973...would like to do a ka24de nat. aspirated swap....can you guys help me steer in the right direction with engine mounts...tranmission suppor etc...thanks..if any of you have already build one would like to see it...Im here in San Fernando Valley L.A,thanks 1 Quote Link to comment
]2eDeYe Posted August 7, 2019 Report Share Posted August 7, 2019 Not many KA swapped 610s out there. Not many 610s to begin with really. The dual cam KA is a front sump motor, so that will be the first thing you need to look into. Quote Link to comment
datzenmike Posted August 8, 2019 Report Share Posted August 8, 2019 Examine the late D21 Hardbody truck. It has a horizontal intake with a throttle body mounted like a carburetor. Just make an aluminum adapter plate and mount a Weber carb. As the EFI won't be needed and the stock ignition is run by it and a CAS you can simply swap in an L20B distributor and away you go. 1 Quote Link to comment
