Joshj124 Posted April 29, 2019 Report Share Posted April 29, 2019 So I am trying to lift my 1981 b210 any one no of a kit that would work 1 Quote Link to comment
datzenmike Posted April 29, 2019 Report Share Posted April 29, 2019 Usually cars get lowered, going 4x4-ing? 1 Quote Link to comment
]2eDeYe Posted April 29, 2019 Report Share Posted April 29, 2019 There are various ways to accomplish this, although there are no kits. What is your goal? 1 Quote Link to comment
Joshj124 Posted April 29, 2019 Author Report Share Posted April 29, 2019 I want a 2 to 3 inch lift it's a off road rally car 1 Quote Link to comment
datzenmike Posted April 29, 2019 Report Share Posted April 29, 2019 Have the rear leaves re arched or add a leaf. (off road will be rough so stiffer springs are less likely to bottom out) For the fronts a rubber coil spring spacer... 3 Quote Link to comment
]2eDeYe Posted April 29, 2019 Report Share Posted April 29, 2019 Also, leaf springs setup for travel can use a longer shackle, you want to make sure it sits at about a 45 deg angle at ride height for proper spring travel. Strut tubes can also be lengthened easier than they can be shortened, with a sleeve. 2 Quote Link to comment
]2eDeYe Posted April 29, 2019 Report Share Posted April 29, 2019 Another thing is that your front lower control arms may need to be lengthened to maintain camber. 2 Quote Link to comment
