protekjv Posted September 10, 2018 Report Share Posted September 10, 2018 (edited) I have 1985 720 it has 3 speed auto transmission, I want to swap for 5 speed transmission soon, I got the basic parts that I need for the swap. My question do I also need the wiring hardness from a manual 720 truck? Edited September 10, 2018 by protekjv 1 Quote Link to comment
datzenmike Posted September 10, 2018 Report Share Posted September 10, 2018 The auto has an interlock that disconnects the start signal from the starter so it cannot be fired up in gear. Just connect the Brown and the Blue/Red stripe wires together. The other two wires on the interlock (Yellow/White and Yellow/Red) are for the reverse lamp switch. Just plug into the reverse light switch just to the rear of the clutch arm dust boot on the 5 speed. You will need to pry off the automatic plate that covers the end of the crankshaft. The crankshaft will also need a pilot bushing put in. Only >$5 but have to have it. 1 Quote Link to comment
Charlie69 Posted September 11, 2018 Report Share Posted September 11, 2018 (edited) When you get ready to do this I will trade you, pedal boxes with pedals, emergency brake handle assembly with the kick down switch, gas pedal with the kick down switch tab, the floor shifter with the transmission cover plate and linkage. For the shifter as you probably will get one with the transmission I will supply you with the clutch master, hard line, hydraulic hose and the slave cylinder with the rod. I would be interested in buying any of these automatic parts from you if you already have any of the parts mentioned. Be sure when you get the trans you get the through out bearing arm/fork and the through out bearing. Install new through out bearing on the through out bearing sleeve. Get theold clutch with the flyweel in case you need a core for a new one. Get the fly wheel bolts with the flywheel as they are longer than the automatic flex plate bolts. Edited September 11, 2018 by Charlie69 Quote Link to comment
