SUPER_YOCOM Posted July 11, 2018 Report Share Posted July 11, 2018 (edited) I have a base 84 2wd 720 205/70/14 tires My speedo is way off.At 35mph it reads 55.55mph reads 75ish ,70mph reads 95ish.Speedo starts off at zero. Could I just need a good cluster? Is a 4x4 compatible? Thanks,Yocom Edited July 11, 2018 by SUPER_YOCOM gramer 1 Quote Link to comment
MikeRL411 Posted July 11, 2018 Report Share Posted July 11, 2018 Sounds like you have an SAE transmission drive and a metric speedometer cluster! 56 KPH is just about 35 MPH. 1 Quote Link to comment
datzenmike Posted July 11, 2018 Report Share Posted July 11, 2018 The speedometer gauges will all be the same only the numbering on the dial would be different. The Canadian dial reads KPH on the outside and MPH (in smaller numbers) just inside them. If the differential has never been changed then the gauge is messed up. A 4x4 gauge will be fine. 1 Quote Link to comment
SUPER_YOCOM Posted July 11, 2018 Author Report Share Posted July 11, 2018 Big Thanks too both Mikes.I really think your right!! Just how hard would it be to fined a metric overlay? Thanks,Yocom 1 Quote Link to comment
