Mike Phillips Posted November 6, 2008 Report Share Posted November 6, 2008 Seat Belt Assembly? - 1974 Datsun Truck Need help figuring out how these are supposed to be assembled? This is how the seatbelts were when I bought the truck. The shoulder belt on both sides is connected to the latch but the belt that's on each end of the seat is disconnected? Can someone explain or post a picture as to how the unconnected belt is supposed to attach to the latch? Quote Link to comment
Guest Rick-rat Posted November 6, 2008 Report Share Posted November 6, 2008 the belts that latch together should be your lap belts and the shoulder belt shoud have an attachment that hooks into the rounded slotted male end of the lap belts. changed mine out for set up with auto retracting shoulder belt Quote Link to comment
Mike Phillips Posted November 6, 2008 Author Report Share Posted November 6, 2008 Thanks. Looks like someone in the past removed the attachment off the shoulder belt and then threaded it onto the lap belt component making the normal outer lap belts useless. There's a single 1975 Datsun Truck in our local wrecking yard, I'll see if the attachment is still on the end of the shoulder belts. I inspected the belt material on the driver's side of the one in the wrecking yard and it was all worn and frayed but hopefully the attachment is still on it. Did you get your retractable belts out of a late model Datsun or Nissan truck? :) Quote Link to comment
Pacific coast Datsun Posted November 6, 2008 Report Share Posted November 6, 2008 I have that style belt in my 72 wagon. On my 620 [74] I got retractable belts out of a newer 620 fron a JY. Sorry forgot the year but youll know it when you see it. Quote Link to comment
Guest Rick-rat Posted November 6, 2008 Report Share Posted November 6, 2008 I got my new belts from Partsamerica, but you should be able to find some in a J/Y Quote Link to comment
datsunaholic Posted November 6, 2008 Report Share Posted November 6, 2008 The '75 belts are slightly different from the '74 ('72-74 were the same). Better, just find a '76-79 and take the entire assembly (both parts). They're retractable with the shoulder part integrated like normal modern belts, and they will fit a '74 with only a little weirdness (the lower outer mount is in a slightly different location). I've done it with my '74. Quote Link to comment
