Sign in to follow this
dgi
78 bumpers
1978 Datsun 280z with the ridiculous park bench bumpers.
Does anyone have any tips about moving the stock front bumper closer to the body?  I know most everybody prefers the smaller bumpers of the early Z cars and I do too, But, at the moment I just would like to move the stock bumper back.
If you have done it or have pictures of a Z with these bumpers moved back, I sure would appreciate a tip on how to do it or pictures of one already done.
dgi
Share this post
Link to post
What I did on my 710 was nick the bumper shock with an angle grinder to let the pressurizes nitrogen? and oil out. Then it was a simple job of kicking the chrome bumper back towards the car as the shock collapses. I had to trim a rubber valance to get more room.
Share this post
Link to post
I did much the same as Mike. I drilled through the outer pipe and then collapsed the shock. We actually took the shock apart and cut a couple inches off so we could collapse it until the chrome was even with the body. We completely removed the rubber if i remember correctly. We also welded the the two halves together once we determined where we wanted them.
The pipe is about 1/4 inch thick so it takes a while to get through.
Remove the screw in the center of the front of the shock, behind the bumper, to depressurize it first.
Share this post
Link to post
Thanks for the responses.  Pretty much what I was thinking,   Not sure how the rubber will line up though.
The bumpers are coming off before the 21st for the car to go to the paint shop.   I will take a closer look then,
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
