ratsun.818 Posted August 2, 2017 Report Share Posted August 2, 2017 Hello everyone so only my left turn signal turns works when I hit the switch. Yet when I try to signal right the light in the cluster and the light on the turn signal don't come on. However, the hazards work perfect. I have an extra used turn signal switch I found lying around but it's funny because it works vice versa (left signal doesn't work & right signal does work) so technically, do y'all think it's just the turn signal switch? Thanks in advance m8's Quote Link to comment
Crashtd420 Posted August 2, 2017 Report Share Posted August 2, 2017 Yup.... it's probably a broken solder on the switch or just not making contact.... on my 521 it slide on a plastic contact plate .... mine broke so only half worked also... take a closer inspection and you should see something either broken or corroded.... Quote Link to comment
datzenmike Posted August 2, 2017 Report Share Posted August 2, 2017 By your description, it's the switches. They appear to have the same problem but on opposite sides. The 620 shares the turn signal with the brake light so the switch disconnects the brake on that side before connecting the flasher to it. If you watch you can see the contacts open before connecting to the flasher. Mine had huge blobs of solder on the wires. One came undone but it was an easy fix. Quote Link to comment
ratsun.818 Posted August 2, 2017 Author Report Share Posted August 2, 2017 Yeah i figured i just had 2 faulty swicthes thanks guys! Quote Link to comment
