Javi_Mayne Posted June 15, 2017 Report Share Posted June 15, 2017 So I finally have an sr for my b310. I noticed that CX racing has a kit for the 510, for the sr. Will that work for me? What do you guys suggest? Quote Link to comment
Javi_Mayne Posted June 15, 2017 Author Report Share Posted June 15, 2017 Suggestions?? Quote Link to comment
Lockleaf Posted June 15, 2017 Report Share Posted June 15, 2017 I don't know anything about b310s, so id suggest checking Australia, South Africa, and your local welding supply shop. Quote Link to comment
flatcat19 Posted June 15, 2017 Report Share Posted June 15, 2017 Suggestions??The 510 mounts won't work because of your crossmember. The towers stick up way too high on one side. Fabbing that will be your answer. I looked on Mad Dat's website to see if they have conversion mounts...they used to. Does not look like they currently do. Another option would be an A10 cross member. What did your Google results come up with for solutions? Mine found me this: http://datsun1200.com/modules/mediawiki/index.php?title=SR_engine_swap 2 Quote Link to comment
Javi_Mayne Posted June 18, 2017 Author Report Share Posted June 18, 2017 I know maddat sells a kit for the 1200, do you think that would work for the B310 since they are both A-series? Quote Link to comment
flatcat19 Posted June 18, 2017 Report Share Posted June 18, 2017 Their kit would probably work for the B210, but not the B310. Again, A10 cross member. Read the link I posted above. Quote Link to comment
MrWhite Posted July 2, 2017 Report Share Posted July 2, 2017 I used a crossmember from a 82 200sx, everything bolts up. I even used the motormounts. I believe a 510 crossmember from 79 and 82 will also. Quote Link to comment
