LUIS COLCHETE Posted April 25, 2017 Report Share Posted April 25, 2017 Hi! I dont stop, its really fascinating, restoring and upgrading engine, brakes and now dash. I will coat the dash with wood, but i will need new things: gps speedometer (its easy) tachometer (easy) but fuel gauge and sender, temp gauge and sender (thread on head i dont know if exists) are my problem. Or find an used gauge temp/fuel/ Datsun 1200 coupe in good shape Please let me know a solution Thanks to all membbers of community Luis Quote Link to comment
Draker Posted April 25, 2017 Report Share Posted April 25, 2017 The senders you can find and can be shipped to you. Post an ad in the classifieds. As far as the gauges.. are you looking to find OEM gauges? If you want aftermarket, speedhut makes some really nice gauges that will work for you.. but they aren't cheap. They are custom built for you.. so you can customize them to your liking. Quote Link to comment
LUIS COLCHETE Posted April 25, 2017 Author Report Share Posted April 25, 2017 Thanks I try to find OEM temp/fuel gauge from a Datsun 1200 coupe and i think my senders works welll and the the solution is cheaper. I cant ad on classifieds Sppedometer its easy gps one Quote Link to comment
Draker Posted April 25, 2017 Report Share Posted April 25, 2017 PM a moderator to allow you to post in the classifieds. Quote Link to comment
LUIS COLCHETE Posted April 25, 2017 Author Report Share Posted April 25, 2017 I do the advertise now thanks Quote Link to comment
LUIS COLCHETE Posted June 19, 2017 Author Report Share Posted June 19, 2017 Just arrived new gauges... I wiil need a new nut modification for water temperature sender Quote Link to comment
Draker Posted June 19, 2017 Report Share Posted June 19, 2017 Good choice on gauges! Can't go wrong. Quote Link to comment
LUIS COLCHETE Posted June 20, 2017 Author Report Share Posted June 20, 2017 I have on doubt: All A12 A14 Cylinder head has the the same port thread m16 * 1.5? to the temperature sender I must find a coollar nut with: 1/8 27 npt Female to m16 * 1,5 male Any sugestion Thanks Luis Quote Link to comment
Crashtd420 Posted June 20, 2017 Report Share Posted June 20, 2017 Quick searched will turn up what you need... also saw available through advance auto.... type in the part number it should show you a couple places to buy... Quote Link to comment
