¿Starter swap?
RasselFlassel13
  • Replies 4
All Z series should work. L series will also work as the solenoid leans away from the block. Z series do not work on L series very well as the solenoid hits the dip stick tube. You can dent the tube but will need a thin flexible dip stick. I've done this..
