720s Posted December 4, 2016 Report Share Posted December 4, 2016 does anyone know why my fan & ac isn't working the light goes on but nothing blows at all could it be a fuse that is blown out ??? 1 Quote Link to comment
datzenmike Posted December 4, 2016 Report Share Posted December 4, 2016 I don't know can't see. Take a look at the 10th fuse over from the left side of the fuse box. It's 20 amp, the only 20 amp in the box. If obviously blown OK, if not obvious, it's best to replace as a visual is unreliable. You could try a 15 amp on low speed to see it that's it. 2 Quote Link to comment
la_leo Posted December 5, 2016 Report Share Posted December 5, 2016 I don't know can't see. Take a look at the 10th fuse over from the left side of the fuse box. It's 20 amp, the only 20 amp in the box. If obviously blown OK, if not obvious, it's best to replace as a visual is unreliable. You could try a 15 amp on low speed to see it that's it. hard to diagnose electrical over the forum. The 720 I'm working on has entire rat and or mice nests in the dash! I'm going to have to pull everything out to get the blower fan clan. 1 Quote Link to comment
720s Posted December 5, 2016 Author Report Share Posted December 5, 2016 I'm lost but when I try to turn my ac on their is no air or sound coming out but the light is on for the ac 1 Quote Link to comment
datzenmike Posted December 5, 2016 Report Share Posted December 5, 2016 The same fan works the heater. Does the fan come on with the heater? If yes then the fan is good. 1 Quote Link to comment
Lockleaf Posted December 5, 2016 Report Share Posted December 5, 2016 The fan switch is the side to side motion of that lever. The a/c is switched by pulling on that lever. If the light comes on but no fan action is going on, that means your a/c is grounding but the fan isn't. Does the fan work on high speed? 1 Quote Link to comment
