Kenmataya Posted November 29, 2016 Report Share Posted November 29, 2016 Hello, I'm in the process of replacing my re-upholstered dash and i took photos of the ignition switch connects, 3 in fact. unfortunately all 3 are blurry..... if anyone could help me out on the correct wiring connection i would greatly appreciate it! Thanks, Ken Quote Link to comment
jfbrink Posted November 29, 2016 Report Share Posted November 29, 2016 Black/Yellow to Start terminal Black/White to Ignition terminal White to Battery terminal The terminals are marked with little raised letters on the black plastic backing. Quote Link to comment
Kenmataya Posted November 29, 2016 Author Report Share Posted November 29, 2016 awesome - thanks! if the wiring is original! Ken Quote Link to comment
Kenmataya Posted December 13, 2016 Author Report Share Posted December 13, 2016 had a clear top pic, all good to go. there were no letters on the back plate tho. Quote Link to comment
jfbrink Posted December 13, 2016 Report Share Posted December 13, 2016 Mild inconvenience, but not a big deal. The following assumes you have only three tabs at the back of the switch: 1. Get a device that measures continuity. 2. Turn the key to the first position. Test which two tabs have continuity. One is B+ and one is IGN. 3. Turn and hold the key in the second position. Test which two tabs have continuity. The one you also touched in (2) is B+ the other is ST. Done. Jesse. Quote Link to comment
datzenmike Posted December 13, 2016 Report Share Posted December 13, 2016 Are the wires not in a plastic plug? No way to mix them up. Quote Link to comment
jfbrink Posted December 13, 2016 Report Share Posted December 13, 2016 No way, man. You boys with your "modern" cars.... Quote Link to comment
datzenmike Posted December 13, 2016 Report Share Posted December 13, 2016 I hear that! Quote Link to comment
