'74 B-210
B-210 GX
  • Replies 2
A14 from the later '75 and on B-210
A15 from the much later '78 and up 210 (B310)
These should bolt right in if you can find a good runner or rebuild one from a core.
There are other engines for sure but you woiuld also need the transmission, rad engine mounts and probably the cross member swapped.
