sdsurf Posted October 25, 2008 Report Share Posted October 25, 2008 I noticed the other day after letting my truck ('70 pl521) idle that the level of gas in my carb had creeped above the float line level. This is the stock hitachi carb. The truck is not in driving condition I had just let it idle for about 15-20 minutes. WHen I first started it the level was right at the float line. What or why would it fill up more? Quote Link to comment
OL YELLER Posted October 25, 2008 Report Share Posted October 25, 2008 check the needle at the float tang...could be worn and allowing gas to leak by, replace it if you can find a rebuild kit Quote Link to comment
Nicholas7620 Posted October 31, 2008 Report Share Posted October 31, 2008 Change your gas filter(s), It doesn't take much dirt to screw up your float. It your truck has been sitting then you should get some Heet in your gas tank to soak up and burn off any water that may have condensed in your gas tank. Quote Link to comment
dat521gatherer Posted November 2, 2008 Report Share Posted November 2, 2008 check it by tapping on it with a hammer. this will usually make the valve seat seal and the fuel level go back to normal. this is not a fix but a test. tap on the bolt/needle seat valve that the fuel line attaches to while it's running. Quote Link to comment
racerx Posted November 3, 2008 Report Share Posted November 3, 2008 Here try this... http://dimequarterly.tierranet.com/articles/tech_carb_tuning_guide.html Quote Link to comment
sdsurf Posted November 3, 2008 Author Report Share Posted November 3, 2008 I have a rebuild kit but all it contains is gaskets. Should I do this and clean out all of the jets with carb spray. At least I can remove the 37 yrs of gunk accumulated. Quote Link to comment
sdsurf Posted November 3, 2008 Author Report Share Posted November 3, 2008 Also, The choke (electric) never opens up. I don't have the choke wire hooked up currently. Quote Link to comment
Cuts metal like mad Posted November 3, 2008 Report Share Posted November 3, 2008 it wont open if its not hooked up... its closed normally. Quote Link to comment
datzenmike Posted November 4, 2008 Report Share Posted November 4, 2008 Connect the choke to any fuse that is switched on with the ignition. Quote Link to comment
