banzai510(hainz) Posted September 18, 2016 Report Share Posted September 18, 2016 its a Japanese import motor for the 90s and right hand drive car. Most likely a W53 head on there also I wouldn't wast my time turboing a dual carb set up. just run them. Its will be fun enough. Youll just have proplems blowing up the carbs. Making a pressure box is a nightmare and why build when you can drive it now. Quote Link to comment
Cosmonaut Posted September 18, 2016 Author Report Share Posted September 18, 2016 Not planning on putting a turbo on it. Just found this interesting. Paragraph from the link above: "The SK Racing carb was also designed to be sealed and that it can be pressurized up to 16PSI to be used in a blow through turbo setup." Did some further reading, these carbs do NOT need to be boxed for a blow thru turbo application. Quote Link to comment
