Forjen620 Posted April 7, 2016 Report Share Posted April 7, 2016 My turn signals aren't blinking. Got out and checked the bulbs and they work, just not flashing. Stays lit on the dash too. Solutions? Thanks. Quote Link to comment
flatcat19 Posted April 7, 2016 Report Share Posted April 7, 2016 Do your 4 ways work? Quote Link to comment
kmc63 Posted April 7, 2016 Report Share Posted April 7, 2016 check your flasher can under the dash. Quote Link to comment
datzenmike Posted April 7, 2016 Report Share Posted April 7, 2016 You didn't say if only one side does not work or both. Turn 4 ways on and go look at every corner. Is there a bulb not flashing? Change it. If 4 ways work find the two flasher units under the dash beside the steering column and switch them. If turns start working then the flasher unit was bad. Quote Link to comment
Forjen620 Posted April 7, 2016 Author Report Share Posted April 7, 2016 Ok, so the 4 ways work, just not the turn signals. Quote Link to comment
datzenmike Posted April 7, 2016 Report Share Posted April 7, 2016 Next find the flasher units and swap them. This will isolate a bad flasher if there is one. Hell the turn signal flasher might even be missing. I think the 620 has a white plastic thing with two clips that hold the flashers. The clip might be attached to the steering column or nearby. Quote Link to comment
