720driver97 Posted April 4, 2016 Report Share Posted April 4, 2016 I was going to get Dana's for my sas but the axles I was looking for were sold, today I found some fj40 axles for cheap I was wondering how they would work in my truck Quote Link to comment
Lockleaf Posted April 4, 2016 Report Share Posted April 4, 2016 What's the wms on them? Quote Link to comment
720driver97 Posted April 4, 2016 Author Report Share Posted April 4, 2016 55 inches wide if that's what you're asking Quote Link to comment
Lockleaf Posted April 4, 2016 Report Share Posted April 4, 2016 That should be fine. (Wms is wheel mounting surface, distance from where one wheel mounts to where the other wheel mounts) Distance between leaf spring mounting pads on the axle is the next most important question. That will tell you how close it will come to bolting in on the rear. Otherwise, What is it that you are really wanting to know? Quote Link to comment
720driver97 Posted April 4, 2016 Author Report Share Posted April 4, 2016 I was wondering on the strength of the axles and what problems I might run into with them Quote Link to comment
mike Posted April 4, 2016 Report Share Posted April 4, 2016 40 axles are plenty strong... Don't know what engine/trans/t-case you plan on running but the rear diff is offset to match the front, its not centered... unless its a really early one. Cruiser t-cases are tough as nails, and if you're running a gm/dodge/ford drivetrain that will take a 203 t-case you can make a pretty cheap doubler with an early 3 speed cruiser t-case... I forget the years (before 73) its the one with straight cut gears. If the cruiser axles are drum brakes you're going to probably end up spending more converting them to disk and figuring out your drivetrain issues than if you were to just get a set of 44s from a scout or some yota mini truck axles. Id go yota mini truck myself just because of the ease of gear swaps/setup... Quote Link to comment
720driver97 Posted April 4, 2016 Author Report Share Posted April 4, 2016 Ok thanks, I got the stock z24 engine and the stock divorced the case. I noticed the offset diff can I just swing the drive shaft over or is there more to it? They are out of a 74 and they already got disk brakes Quote Link to comment
Boxcar Posted April 5, 2016 Report Share Posted April 5, 2016 It can be and has been done. Not a great idea though creates a bind.. Your stock T case is going to be an issue as well as it has a centered. front output. Quote Link to comment
720driver97 Posted April 5, 2016 Author Report Share Posted April 5, 2016 Will it pinch the drive shaft at a angle too much? What would be a good transfer case to swap in, eventually I want to have a doubler Quote Link to comment
Lockleaf Posted April 5, 2016 Report Share Posted April 5, 2016 If you want to keep it in the Nissan family you could get a four wheel drive transmission from a D21. They are a married T case on the back of the transmission. Then still use your factory t100 tcase as your Doubler t-case but when you install it put it in at an angle so the output shafts are on the correct side of the vehicle to go to the differentials. Otherwise start shopping for Toyota or GM parts because that's where most of the aftermarket is found Quote Link to comment
720driver97 Posted April 5, 2016 Author Report Share Posted April 5, 2016 Could I angle the t case I have now for the time being? Quote Link to comment
Lockleaf Posted April 5, 2016 Report Share Posted April 5, 2016 I think you could get away with that, yes. Boxcar and Stoffregen Motorsports are the two best 4x4 guys on here. Might be worth throwing a pm at both of them to see what they think of doing so. Quote Link to comment
720driver97 Posted April 5, 2016 Author Report Share Posted April 5, 2016 Ok, by the way what is the ratio on our tcases in 4 low? Quote Link to comment
Lockleaf Posted April 5, 2016 Report Share Posted April 5, 2016 1:1 in high, 1:2.07 in low And as far as i can tell, the tx10 for the d21 is 2.6 in low. Quote Link to comment
720driver97 Posted April 5, 2016 Author Report Share Posted April 5, 2016 Ok thanks 1 Quote Link to comment
