720driver97 Posted March 26, 2016 Report Share Posted March 26, 2016 What would it take as far as parts and difficulty to convert the z24 over to efi? Quote Link to comment
datzenmike Posted March 26, 2016 Report Share Posted March 26, 2016 The 720 Z24 after April '85 had EFI. All Z24 powered D-21 Hardbodys were throttle body EFI. Quote Link to comment
Lockleaf Posted March 26, 2016 Report Share Posted March 26, 2016 http://nissannut.com/projects/z24i_fuel_injection/ This guy started out converting his carb motor to efi then found tons of little differences and ended up getting a compete z24i. He covers what he did decently though. If you were to attempt it, minimum will be intake manifold, tbi, distributor (actually a crank angle sensor), oil pump drive shaft, timing cover, ecu, wiring harness. Likely additional stuff as well Quote Link to comment
