85"720 Posted February 21, 2016 Report Share Posted February 21, 2016 I did a compression test on my truck and this is what I got Intake#1 160psi Intake#2 165psi Intake#3 155psi Intake#4 165psi Exhaust#1 120psi Exhaust#2 103psi Exhaust#3 130psi Exhaust#4 120psi My question is shouldn't the exhaust side be almost the same as the intake or is this normal. Motor has 130k original miles Quote Link to comment
datzenmike Posted February 21, 2016 Report Share Posted February 21, 2016 Yes they will be identical.... so your method is wrong somehow. Warm the engine to operating temperature and be sure the other plug is in snugly. You only need to do one hole per cylinder. If the rubber end type that you push and hold, be sure it is securely held and no compression escapes. If the screw in type be sure it is in a tight. Take two or three readings and average them. They should all be within a pound or two or the compression tester is faulty. I wouldn't do a compression test until all the valve clearances are checked. Quote Link to comment
flatcat19 Posted February 21, 2016 Report Share Posted February 21, 2016 Did you do the intake side first? Maybe by the time you got to the exhaust side your battery was starting to feel the burn. Put a charger on it to keep a consistent voltage while performing your tests. Quote Link to comment
85"720 Posted February 22, 2016 Author Report Share Posted February 22, 2016 I did the exhaust side first the other day and did the intake yesterday. I did it on a hot engine both times. I did one plug at a time. I still need to get them adjusted. So both sides should read identical then? Quote Link to comment
datzenmike Posted February 22, 2016 Report Share Posted February 22, 2016 Yes they will be identical.... so your method is wrong somehow. Warm the engine to operating temperature and be sure the other plug is in snugly. You only need to do one hole per cylinder. If the rubber end type that you push and hold, be sure it is securely held and no compression escapes. If the screw in type be sure it is in a tight. Take two or three readings and average them. They should all be within a pound or two or the compression tester is faulty. I wouldn't do a compression test until all the valve clearances are checked. Quote Link to comment
