sanyantho Posted January 5, 2016 Author Report Share Posted January 5, 2016 Hi Hainz, What is the benefit of going with the Pertronix? Thanks Quote Link to comment
datsunaholic Posted January 5, 2016 Report Share Posted January 5, 2016 Pertronix kits are simply solid-state replacements for points. Points are mechanical and wear out, both the cam follower and the actual breaker points only last so long. The Pertronix, being magnetic and using a solid-state ignitor, removes those wear items making for a more reliably-timed spark. But the drawback is you don't get a HOTTER spark (allowing for wider plug gaps) because you still have to use the high-resistance coil or teh ballast resistor. Otherwise, the current draw is too high and it fries the pertronix unit. 2 Quote Link to comment
datzenmike Posted January 6, 2016 Report Share Posted January 6, 2016 Get a later L20B '78 remote igniter or '79/'80 matchbox distributor. They both do the same thing but the matchbox module is just the '78's remote igniter that has been miniaturized. Both handle a lot more current than the Pertronix and can use a matching lower impedance coil for a much hotter spark. 1 Quote Link to comment
