pipefitter Posted November 8, 2015 Report Share Posted November 8, 2015 Hey Ratuners,I joined up last year when I put disc brakes on my dottie and could not get them to work good.I ended up taking her to the mechanic I go to when I cant figure out what to do,he had her for about 6 months messing around with her when he had spare time and told me finally it was the master cylinder but didnt know which way to go from there so I picked it up and started to look online for a solution,that is when I found ratsun,wow what a great wealth of info there is here I posted the question and within a hour I had the answer" get a 1980 zx master cylinder it will fit right on" it was that easy.So thanks for the help and everyone that post on here I read it constantly and have learned alot,anyway I decided to do some work on the dottie and things went alittle crazy because 2 months later and I am still doing stuff but I guess thats how it usaully goes. here a pic of what I started with 2 Quote Link to comment
]2eDeYe Posted November 8, 2015 Report Share Posted November 8, 2015 Good looking 620 you got there. How about some more pics. :D Quote Link to comment
Ratwagon1600 Posted November 8, 2015 Report Share Posted November 8, 2015 "I found Ratsun, wow" I say this constantly :rofl: What Redeye said mate, more pics for the pic whores. Personally i'd be interested in seeing the suspension setup. We dont get a heap of 620's with raised suspension down here. 1 Quote Link to comment
pipefitter Posted November 8, 2015 Author Report Share Posted November 8, 2015 trying to figure out this bucket stuff so will get some pics soon.as for the running gear it has a low converson kit dana 27 in the front and datsun rear with the springs on top 1 Quote Link to comment
pipefitter Posted November 9, 2015 Author Report Share Posted November 9, 2015 So I think I got this bucket figured out.Anyway this what I started out to do the valves where ticking away so I adjusted them to having it just as noisy,I contacted the PO (we still keep in touch) and asked him if in the 450,000 he put on this truck and three motors later if he ever replaced the timing chain when he said no I knew what was making noise and I figured might as well do the clutch o I started pulling out the motor. 1 Quote Link to comment
pipefitter Posted November 9, 2015 Author Report Share Posted November 9, 2015 so out she comes and I am Just planning on pulling the tranny off putting in a clutch and timing chain. 1 Quote Link to comment
]2eDeYe Posted November 9, 2015 Report Share Posted November 9, 2015 Interesting steering. Uses the stock idler arm as a bell crank, I like it. :) Quote Link to comment
pipefitter Posted November 9, 2015 Author Report Share Posted November 9, 2015 So in the middle of all this my buddy calls me and says I know you like datsuns check this out he found on craigs list,it was listed under sss it did not come up under datsun motors or anything else weird uh,any way I am taking this with a grain of salt I know people usually think they have something cool but they dont so I go check it out Quote Link to comment
pipefitter Posted November 9, 2015 Author Report Share Posted November 9, 2015 well I looked at the motor and had him pull the pan off and I see dirty oil on the sides of the pan( and I am in his apartment on the porch) so I said the add sounded like a new motor and this one had been run ,he said he put 1000 miles on it to make sure it was good.I know I know but it did look pretty fresh and looked to have some nice machined pistons water pump fuel pump flex plate so I bought it now just hope it runs decent. Quote Link to comment
pipefitter Posted November 10, 2015 Author Report Share Posted November 10, 2015 zWell I got the motor and painted it up 1 Quote Link to comment
pipefitter Posted November 10, 2015 Author Report Share Posted November 10, 2015 well know the motor is out I might as well cleanup the motor compartment,it looks kind of nasty Quote Link to comment
pipefitter Posted November 10, 2015 Author Report Share Posted November 10, 2015 being that I am a so so mechanic I figure I better pull everything off one side at a time so I can remember where everything goes back at 1 Quote Link to comment
pipefitter Posted November 10, 2015 Author Report Share Posted November 10, 2015 1 Quote Link to comment
pipefitter Posted November 10, 2015 Author Report Share Posted November 10, 2015 then its on to some fun shit 1 Quote Link to comment
pipefitter Posted November 10, 2015 Author Report Share Posted November 10, 2015 now that I got going its hard to stop so I might as well keep going so I will add more goodies.I think I will maybe paint the cab and maybe make a flat bed I could use a tr.uck to get around the dairy fields around here and do some side jobs ,I dont know I will have to think on it. 1 Quote Link to comment
mcordero8 Posted November 10, 2015 Report Share Posted November 10, 2015 Looks like it doesn't have a lot of rust. I like it. Keep up the good work! Quote Link to comment
Boxcar Posted November 10, 2015 Report Share Posted November 10, 2015 You are doing nice work. Keep it up and us posted. PS: Add a fuel regulator between the pump and the Weber . Set at 2.5 lbs. Quote Link to comment
q-tip Posted November 10, 2015 Report Share Posted November 10, 2015 Very nice, good to see another 4x4 620 on the site! Quote Link to comment
pipefitter Posted November 11, 2015 Author Report Share Posted November 11, 2015 Thanks for the advise its always welcomed.Am working out a flatbed frame will have pics soon Quote Link to comment
pipefitter Posted November 11, 2015 Author Report Share Posted November 11, 2015 Thanks for the advise its always welcome,working out a flatbed frame will have pics soon. Quote Link to comment
pipefitter Posted November 14, 2015 Author Report Share Posted November 14, 2015 Well I got back to it alittle,I ajusted the valves,static timed it and set the carb to starting adjustments then I got all the new clutch stuff in and bolted up the tranny.Ready to put back in. 1 Quote Link to comment
pipefitter Posted November 14, 2015 Author Report Share Posted November 14, 2015 OK motor is all back in time to hook up all the little stuff,still have to cut in the fuel reg set at 2.5 lbs(thanks) should be here monday and I can get ready to fire it up. 1 Quote Link to comment
