Cardinal Grammeter Posted October 28, 2015 Report Share Posted October 28, 2015 Installing the OEM carb with nothing to go by. Saw a little bracket on the throttle shaft that stacked on top of the cable "arm." So I looked it up in the on-line parts manual. It is #76 called a Spring Bracket (most likely for Spring #75): I have no idea where this goes (possibly to the little bracket the throttle cable sheath end is fixed to?) Here is the carb parts figure: Quote Link to comment
datzenmike Posted October 28, 2015 Report Share Posted October 28, 2015 My info shows it as spring assist 16145-B7900. The throttle return spring is really #25 or #26 1 Quote Link to comment
Cardinal Grammeter Posted October 28, 2015 Author Report Share Posted October 28, 2015 I was assuming it was a throttle spring since its on the throttle linkage. What they call #75/6 doesn't explain much. The parts pic does not explicitly show the #75 spring on the #76 bracket - and obviously no info on what the #75 spring connects to. 75 SPRING-ASSIST 16145-B7900 L18 - 1 76 BRACKET-SPRING 16137-B7900 L18 - 1 Quote Link to comment
