720driver97 Posted August 17, 2015 Report Share Posted August 17, 2015 Will the r1 carbs work on a ka head, also dose it matter the year of the carbs? Quote Link to comment
datzenmike Posted August 17, 2015 Report Share Posted August 17, 2015 http://community.ratsun.net/topic/7862-r1-carbs-lots-of-pics/ Answer is likely here. Quote Link to comment
720driver97 Posted August 17, 2015 Author Report Share Posted August 17, 2015 OK thanks Quote Link to comment
datzenmike Posted August 17, 2015 Report Share Posted August 17, 2015 To answer, R-1 carbs were never intended for anything but a 4 cylinder bike but any reasonably small 4 cylinder can be 'adjusted' to make it work with a custom intake. The KA is an EFI engine has has no ignition system as such. Instead it has a crank angle sensor (CAS) and the output from, this plus other sensor inputs are sent to the ECU and a spark signal and advance is generated. If running a carb you will need to remove the CAS and somehow bolt a regular distributor in there. It's almost for sure (buried) in that post on R-1 carbs. You might try Google search using the word Ratsun in it. Maybe R1 carbs on KA engine? ratsun Quote Link to comment
720driver97 Posted August 17, 2015 Author Report Share Posted August 17, 2015 OK I still can't find what year the carbs should be any ideas? Quote Link to comment
Lockleaf Posted August 18, 2015 Report Share Posted August 18, 2015 Dude it's in like the 8th response in that thread. It's also repeated multiple times throughout. 98-01, after that they went fuel injected. Quote Link to comment
720driver97 Posted August 18, 2015 Author Report Share Posted August 18, 2015 OK thanks Quote Link to comment
