Skib Posted October 4, 2008 Report Share Posted October 4, 2008 (edited) Hey guys, my brothers picking up a 1990 harbody truck with a Z24 (I think?, Ill find out for sure when we get it) it needs an intake mani for a side draft carb set up. I dont know anything about these, what kinda of manifold and carbs would it use? [edit] heres a few pics: Edited October 4, 2008 by Skib Quote Link to comment
datzenmike Posted October 4, 2008 Report Share Posted October 4, 2008 (edited) The '90 D-21 would have had a Z24i throttle body motor which uses a crank angle sensor distributor. Now if that really is a Z24 in it then that distributor will work with a carb set up, the Z24i won't. I guess the quickest way to tell is to look at the distributor. The Z24 will have a vacuum advance on the side the Z24i won't. Edited October 4, 2008 by datzenmike Quote Link to comment
Skib Posted October 4, 2008 Author Report Share Posted October 4, 2008 Talked to him and its a Z24 that he was running side draft mikunis on. Quote Link to comment
moparvwfreak Posted October 5, 2008 Report Share Posted October 5, 2008 i like that grille. that would look oh so nice on my pathfinder. Quote Link to comment
datzenmike Posted October 5, 2008 Report Share Posted October 5, 2008 Wow that could take months to find. Go to a local yard and get a stock intake/carb from any '83.5 to 86.5 720 just to get it running. Make sure you don't get an electro carb with the 6 wire connector on it. Quote Link to comment
zed Posted October 5, 2008 Report Share Posted October 5, 2008 another Hardbody on the forum:thumbsup: Quote Link to comment
Skib Posted October 5, 2008 Author Report Share Posted October 5, 2008 Wow that could take months to find. Go to a local yard and get a stock intake/carb from any '83.5 to 86.5 720 just to get it running. Make sure you don't get an electro carb with the 6 wire connector on it. If your talking about the mikunis, I wouldnt be tracking down a nice set of thos for him hahaha Id grab a tripple set for my Z first :fu: thanks for the info. thats exactly what hes looking for, just the stocker to get it running. Quote Link to comment
datzenmike Posted October 5, 2008 Report Share Posted October 5, 2008 Be sure to get a carb only, it will be the easiest. The electro carb requires an ECU for under the pass seat,wiring harness, O2 sensor, crank angle sensor distributor, on and on... avoid this set up. Quote Link to comment
