81sunnyson Posted April 26, 2015 Report Share Posted April 26, 2015 since my engine burns oil i usually just add n change filter i did notice that in the pan the pickup tube is right above the drain plug hole is that normal? the pan is a little dented there but not extreme to where paint is cracked i cant even fit my finger inside, just what "feels" like a pickup tube screen has my pickup tube fallen? Quote Link to comment
datzenmike Posted April 26, 2015 Report Share Posted April 26, 2015 If you can push it around it's off the tube. (it's welded on and unlikely to come off. If the tube was off the engine would have seized way before now. The screen is shallow so the tube is still covered with lots of oil. Quote Link to comment
ggzilla Posted April 26, 2015 Report Share Posted April 26, 2015 Yes it is very normal. The pickup is in the deepest part of the sump. Which also happens to be the best place for a drain Quote Link to comment
81sunnyson Posted April 26, 2015 Author Report Share Posted April 26, 2015 awesome Quote Link to comment
