DatsunThailand Posted April 10, 2015 Report Share Posted April 10, 2015 I purchased this Datsun about a month ago, the body work is a mess but the J15 engine seemed solid until a couple of weeks ago the big ends and main bearings went. Last weekend I completely rebuilt the engine, had the big ends ground to 20thou and re-bored the cylinders + 100thou with pistons to match; replaced the water pump, fuel pump, oil filter, spark plugs, dizzy cap and rotor and gave the Nikki carb a good clean, new fluids etc.. This weekend I should be installing the engine. I opened a topic elsewhere regarding the timing chain but unfortunately got no replies in the matter and due to lack of info on the web I kind of had to just use my knowledge and the limited info I had. I am struggling to find what year the Datsun truck is as things change in Thailand... Can this be found through codes on the VIN Plates. I'll try to keep posting pictures as the project goes on, I'm predicting a long project so maybe far between as well!! 1 Quote Link to comment
sebpv Posted April 10, 2015 Report Share Posted April 10, 2015 Look at the vin plate in the driver door sill. Mine says 1/73 for example 2 Quote Link to comment
DatsunThailand Posted April 10, 2015 Author Report Share Posted April 10, 2015 OK cool, Thanks. 1 Quote Link to comment
Charlie69 Posted April 10, 2015 Report Share Posted April 10, 2015 Here is a link to the J engine service manual scroll to page em-26 (bottom of page) for the timing chain information. You will need a pdf reader to view these. http://www.nicoclub.com/FSM/Engine-Specific/J13,%20J15,%20J16%20series%20Engines/J13,%20J15,%20J16%20Engines%20EM.PDF Here is a link to the J engine Section. http://www.nicoclub.com/FSM/Engine-Specific/J13,%20J15,%20J16%20series%20Engines/ Here is a link to the Datsun Manual Section http://www.nicoclub.com/datsun-service-manuals These are all downloadable for free. Quote Link to comment
DatsunThailand Posted April 20, 2015 Author Report Share Posted April 20, 2015 Engine is back in the car and running sweet! 1 Quote Link to comment
DatsunThailand Posted April 20, 2015 Author Report Share Posted April 20, 2015 Look at the vin plate in the driver door sill. Mine says 1/73 for example The first number right? 2 Quote Link to comment
ggzilla Posted April 20, 2015 Report Share Posted April 20, 2015 Look at the vin plate in the driver door sill. Mine says 1/73 for example That is a FMVSS Build Plate, under USA law. Japan and Australia Datsuns didn't have it. 1 Quote Link to comment
DatsunThailand Posted April 20, 2015 Author Report Share Posted April 20, 2015 That is a FMVSS Build Plate, under USA law. Japan and Australia Datsuns didn't have it. Mine won't have it then. Can you read anything from the VIN under the bonnet? 1 Quote Link to comment
ggzilla Posted April 20, 2015 Report Share Posted April 20, 2015 Nothing, unless you find a table announcing build dates for batches of serial numbers. Sometimes there were published in Datsun documents. Why do you need to know the year? Are there major differences by year? 1 Quote Link to comment
DatsunThailand Posted April 20, 2015 Author Report Share Posted April 20, 2015 Nothing, unless you find a table announcing build dates for batches of serial numbers. Sometimes there were published in Datsun documents. Why do you need to know the year? Are there major differences by year? Not at all, im just interested to know a little about the history of the vehicle... its not a big problem - just me :w00t: !! 1 Quote Link to comment
ggzilla Posted April 20, 2015 Report Share Posted April 20, 2015 Well its a big deal in USA where 620 was fitted with different engines, electrical parts, and suspension/brake parts depending on year. Which is also a way to ID the year ... 1 Quote Link to comment
DatsunThailand Posted April 21, 2015 Author Report Share Posted April 21, 2015 Well its a big deal in USA where 620 was fitted with different engines, electrical parts, and suspension/brake parts depending on year. Which is also a way to ID the year ... It shouldn't be a issue here, a Thai mechanic has been at the car already and done it the 'Thai' way!!! I'm sure there will be a lot of things required and to be replaced to original when I get further into the build. Ill solve them then! By the way... If you're not familiar with the 'Thai way' - it means to fix it anyway regardless. Doesn't matter if you chop everything out as long as the initial problem is fixed fixed! 2 Quote Link to comment
DatsunThailand Posted June 3, 2015 Author Report Share Posted June 3, 2015 Installed Electronic Ignition on the J15 powered Datsun 620!! 1 Quote Link to comment
