Clutch replacement, Nissan 720 4x4
Syphious
  • 1 month later...
  • Replies 119
Replace the first fuse on the far left. 10 amp to get the coil working. The engine is tuned to work on two coils and will run like crap on only one so this may fix everything.
When does it backfire? What are you doing when it does?
I am constantly pressing the throttle pedal, when the rpm’s go down to around 1000 it starts backfiring multiple times. When it backfires I press the throttle pedal.
the ear piercing squeal was back again too, it is not the belt, but I have no idea what it is.
Edited by Datsun pickup
The electrical plug at the back of the carburetor... 2 wires or round 6 wire connector?
Listen near back of carburetor while someone turns ignition on off on off... You should hear a soft clicking sound. Does it do this??? This is the idle cut solenoid and if not working there will be no fuel for idle.
Squeal could be water pump or alternator bearing, air con idler/tensioner bearing, power steering idler/tensioner bearing. Loosen belt completely to fine which one.
Well with both coils firing timing is about 3 degrees BTDC.
If at proper idle speed (about 600-700 RPM) there is no vacuum signal to the vacuum advance. If not, then some vacuum may be messing the timing. Just pull the hose off and check. Engine must be thoroughly warmed up.
Well that ain't right. Power to the coils goes this way...
Battery to...
Fusible link to...
ignition switch... here power splits into..
1/ goes to intake side coil positive terminal
2/ powers the first 5 fuses including the exhaust coil positive terminal
Check the voltage on that first fuse. Lets see what you have here and follow it back.
Green fusible link has no power, well that's your problem. Clean connections and/or be sure to replace with same 40 amp  rated fusible link wire. You could just replace with a 40 amp fuse but the beauty of a fusible link is it can withstand far more than 40 amps for several seconds without blowing. A fuse will blow instantly so carry spares.
3 minutes ago, Datsun pickup said:
With the engine at tdc this is the placement of the rotor pointing towards cylinder 1.
If standing at the driver's side fender looking in the outside rotor (intake side plugs) should point toward the radiator (9 o'clock) and the inner rotor (exhaust side plugs) to about 4:30 o'clock. As in the picture below
If you are absolutely sure that you are at TDC compression stroke on #1 cylinder, then unbolt the distributor and lift it out. Look down the hole with a flashlight, again, from the driver's side fender, and you should see this...
If the 'small side' half moon is on the other side you are on the exhaust stroke TDC. Turn the engine one full turn up to TDC on compression stroke. Now it should look like the picture above. Put distributor back in and check the rotor positions.
Take a picture from the driver's fender, it's the only way for me to see what you see.
