Bosshog Posted February 18, 2015 Report Share Posted February 18, 2015 I picked up a 73 620 a few weeks ago. Lots of rust, clutch was stuck together and fuel tank plugged. Runs pretty good after coil to plugs replaced and all the lights work. Needs floorboards and a seat. I made my own carrier bearing insulator per your suggestions. Thanks. http://s296.photobucket.com/user/Bosshog12/media/100_2195_zps9d5e6aa7.jpg.html?sort=3&o=1 http://s296.photobucket.com/user/Bosshog12/media/100_2199_zpsab3542da.jpg.html?sort=3&o=0 1 Quote Link to comment
datzenmike Posted February 18, 2015 Report Share Posted February 18, 2015 Welcome to Ratsun. 2 Quote Link to comment
Draker Posted February 18, 2015 Report Share Posted February 18, 2015 Looks decent to me. Welcome! 1 Quote Link to comment
ownTer Posted February 18, 2015 Report Share Posted February 18, 2015 Not too shabby there. Keep working and porting pics! And welcome to the forums :) 1 Quote Link to comment
teagueauto21 Posted February 18, 2015 Report Share Posted February 18, 2015 Welcome to ratsun! Looks pretty good. 1 Quote Link to comment
Bosshog Posted February 18, 2015 Author Report Share Posted February 18, 2015 Thanks for the welcome. I am worried about the floor pans since the rust is all around the frame mounts. I was wondering about adding some metal underneath where the pans will go. Any suggestions. I plan on keeping it pretty stock except for the seat (original was gone), different wheel 15 s?, and paint (I don't like the yellow). Also, has anyone added a fan in the cab (no a/c)? It gets hot here. 1 Quote Link to comment
datzenmike Posted February 18, 2015 Report Share Posted February 18, 2015 You should remove the mount bolt and place metal under and weld in. With a hole for the bolt. If not, the cab will rot out and setle down on the frame and nothing looks worse than the cab lower than the bed or tilted. 1 Quote Link to comment
