angelmanuel Posted February 13, 2015 Report Share Posted February 13, 2015 is there a clutch master cylinder with a 3/4 inch diameter that i can use on my 210/B310? does not matter if it is a Datsun part or not so long as i can use it in the car Quote Link to comment
bananahamuck Posted February 14, 2015 Report Share Posted February 14, 2015 http://www.rockauto.com/ should be able to sort through them as most say what size they are,,,,,,,, granted some don't but,, seriously i would just use the size designed for the car Quote Link to comment
datzenmike Posted February 14, 2015 Report Share Posted February 14, 2015 I haven't seen any slave other than the 3/4". Same with the masters. The earlier B-210 for the 4 speed is an exact match also. The unique thing about the A series (4 speed) transmissions is that the clutch arm is on the driver's side. I'm sure other slaves would easily bolt up if flipped over, but the bleeder will be on the bottom below the inlet flex line. If they both have the same thread maybe swap the bleeder and the flex line? Right side slaves are pretty much the same other than the location of the inlet flex line. Trucks are in the end so there is room for the torsion bar. Cars tend to be on the side. Quote Link to comment
bananahamuck Posted February 14, 2015 Report Share Posted February 14, 2015 All the masters i have laying around at my feet say 5/8 ? 1 Quote Link to comment
datzenmike Posted February 14, 2015 Report Share Posted February 14, 2015 Yeah I guess I did say 'same with the masters'. 5/8" would be better. 1 Quote Link to comment
angelmanuel Posted February 14, 2015 Author Report Share Posted February 14, 2015 thanks fo rthe info guys. this is not for a datsun tranny. the one i intend to use says it needs a 3/4 master. or the other option i have is to adapt a datsun slave cylinder and see if it works. does anyone know which slave cylinder has the longes travel? Quote Link to comment
datzenmike Posted February 14, 2015 Report Share Posted February 14, 2015 A 5/8" master normally moves a 3/4" about 1.18". This is the common use for most Datsun 4 and 5 speeds. Quote Link to comment
angelmanuel Posted February 15, 2015 Author Report Share Posted February 15, 2015 thanks for that info, greatly appreciated! Quote Link to comment
