cruznude Posted February 11, 2015 Report Share Posted February 11, 2015 After replacing both both brake cylinders and adding shoes, the drums did not go on and I could not back off the adjusters. They were frozen in place. I removed them and trashed them and now I'm looking for some brand new ones. Does anyone here know where I can pick them up at? My luck it will be Nissan but I don't mend either as long as they are new or used and in working condition.. Quote Link to comment
Guest Rick-rat Posted February 11, 2015 Report Share Posted February 11, 2015 Check Rock auto or if you still have the old ones, put in a vise and you should be able to get them apart, then clean and lube up the threads with anti sieze Quote Link to comment
bananahamuck Posted February 11, 2015 Report Share Posted February 11, 2015 Check Rock auto or if you still have the old ones, put in a vise and you should be able to get them apart, then clean and lube up the threads with anti sieze In brakes ,, Miscellaneous Hardware 8.69 ...... My goofy neighbor puts them in fireplace ,,in the coals for 5 minutes then puts them in oil.. If it doesn't destroy them by melting them,,, they usually free up. Quote Link to comment
MikeRL411 Posted February 11, 2015 Report Share Posted February 11, 2015 In brakes ,, Miscellaneous Hardware 8.69 ...... My goofy neighbor puts them in fireplace ,,in the coals for 5 minutes then puts them in oil.. If it doesn't destroy them by melting them,,, they usually free up. Is he still aiive??????????? Quote Link to comment
