Z-train Posted January 27, 2015 Report Share Posted January 27, 2015 kits are you using? Quote Link to comment
Just Joel Posted January 30, 2015 Report Share Posted January 30, 2015 All the good ones use Eibach springs... Ground control has a better looking collar IMO (construction, looking mechanism) Quote Link to comment
Z-train Posted January 30, 2015 Author Report Share Posted January 30, 2015 Thanks. Quote Link to comment
datzenmike Posted January 30, 2015 Report Share Posted January 30, 2015 Strut tubes are 2" diameter. A narrower coil will leave more room for tire clearance and camber adjustment (if using adjustable camber plates) than a wider one. All things equal,..(wire diameter and number of coils) a narrower coil will have a higher spring rate than a wider diameter coil.. Quote Link to comment
Z-train Posted January 30, 2015 Author Report Share Posted January 30, 2015 Thanks.I picked up ZX strut assemblies and they are going on the 810 Goon as the brakes are about done,the bearings have some play and the outer tie rods are shot also. Might as well upgrade and beside springs for 810's are NLA anywhere. Quote Link to comment
