81SVN20 Posted January 1, 2015 Report Share Posted January 1, 2015 Hello guys I need to know how run the antenna from the fender to the cab is there a hole? This is on my 81 720... 1 Quote Link to comment
datzenmike Posted January 1, 2015 Report Share Posted January 1, 2015 There is a rubber grommet around the main LHD harness on the right side of the firewall. You may be able to peel it back and push the antenna end through. 1 Quote Link to comment
81SVN20 Posted January 2, 2015 Author Report Share Posted January 2, 2015 thanks Mike! will try it out 1 Quote Link to comment
Charlie69 Posted January 2, 2015 Report Share Posted January 2, 2015 If I remember correctly the is a hole under the fender in the upper kick panel that is for the antenna cable to pass through into the cab. Fender has to be off or dash and kick panel cover need to be pulled to see it. Quote Link to comment
Charlie69 Posted January 3, 2015 Report Share Posted January 3, 2015 I checked it out today in the Junk yard and I am correct. Did not have my camera so no picture. Quote Link to comment
