KiloTango1200 Posted December 29, 2014 Report Share Posted December 29, 2014 Here is another time in this build that I am stumped. I pulled the original fuel pump and found a spacer that looks like it is Phenolic. The new fuel pump came with 2 gaskets so it makes sense that the spacer has a gasket on each side. What is this made of and should I remove it and use new gaskets on both sides? The service manuals do not address this. Any help is appreciated. Quote Link to comment
Ranman72 Posted December 29, 2014 Report Share Posted December 29, 2014 yes keep the spacer it is a heat thing and gaskets on both sides be careful they can be brittle Quote Link to comment
KELMO Posted December 31, 2014 Report Share Posted December 31, 2014 If it crumbles in your hand, let me know. I may have on lying around somewhere, or find a current part #. If possible, remove the studs first, then use a putty knife. Quote Link to comment
