ztraviz Posted September 30, 2014 Report Share Posted September 30, 2014 Called cosmetic they said it would be around $2300 just to set up the tooling. So a little help the block has been bored 40 over making it a 90mm. Where can I get a head gasket for the head that is a for 90mm bore? Thanks in advance for your help. Quote Link to comment
datzenmike Posted September 30, 2014 Report Share Posted September 30, 2014 Z24 and KA24E are both 89mm.... maybe there are over size. Quote Link to comment
Sealik Posted September 30, 2014 Report Share Posted September 30, 2014 The Felpro HG is 90+ Quote Link to comment
ztraviz Posted October 2, 2014 Author Report Share Posted October 2, 2014 Will a ka24e gasket work on a z24 Quote Link to comment
MicroMachinery Posted October 2, 2014 Report Share Posted October 2, 2014 Called cosmetic they said it would be around $2300 just to set up the tooling. Do you mean "Cometic"? Quote Link to comment
Stupid_fast Posted October 2, 2014 Report Share Posted October 2, 2014 SCE gaskets make custom copper gasket w/ crush rings. No need to oring block with these. Put copper coat they don't leak.Give them a call. I got one for my L20b. It was $240. I had them make it 89mm bore for the crush ring to fit inside the U67 (because of valve reliefs.)Running turbo or what why do you need MLS? I don't think you need it.. Copper should be fine. If you want to go crazy NOS, or big turbo oring the block. Quote Link to comment
ztraviz Posted October 2, 2014 Author Report Share Posted October 2, 2014 Sorry, yes I ment cometic. Quote Link to comment
D52E Posted October 2, 2014 Report Share Posted October 2, 2014 I had previously asked a similar question on a different site but I never got a response. Maybe someone here can provide some feedback. I was curious if anyone has tried using a KA24DE MLS head-gasket and cutting the timing cover section off for an L20B. Does anyone know if the gasket holes line up correctly for an L-series. I was just thinking it could be an option for members with turbocharged L-series...They come in 90 and 91mm bore. Also, you can order different thickness options. Quote Link to comment
datzenmike Posted October 2, 2014 Report Share Posted October 2, 2014 L,Z and KA engines have the same bore spacing. So an 89mm KA gasket would work on a 83mm L16. However the coolant holes are not located in the same positions. You would likely have to add some holes. Screw buying and replacing gaskets. I'm in the process of making my own 0.020" copper head gasket. So far it's cost me $3.80 and I have enough for two gaskets. Quote Link to comment
