City Hunter Posted September 16, 2008 Report Share Posted September 16, 2008 I'm converting back to a mechanical fuel pump on my 72 z which has a 280z fi engine in it right now. I got a fuel pumper slider deal that goes on the cam bolt to trigger the fuel pump but it seems to hit the valve cover on the l28. My question is, is the l4 engine slider deals different than the l6? Or is my valve cover off this fi engine slightly different. Quote Link to comment
lynchfourtwenty Posted September 16, 2008 Report Share Posted September 16, 2008 u stayin fi? if so i think your gonna run into some problems Quote Link to comment
City Hunter Posted September 16, 2008 Author Report Share Posted September 16, 2008 no im going carbed since im too lazy to fix all the busted fuel injector lines and swap manifolds back over, I have everything but a heat shield right now. Quote Link to comment
philip1 Posted September 17, 2008 Report Share Posted September 17, 2008 the pumps should be the same if it hits the cover you may not have the right pump. Quote Link to comment
datzenmike Posted September 17, 2008 Report Share Posted September 17, 2008 You mean the cam eccentric that works the fuel pump arm? All L series should be the same. When you put the pump on did you remember to put the 1/4" plastic spacer between the pump and the head?????? Quote Link to comment
lynchfourtwenty Posted September 17, 2008 Report Share Posted September 17, 2008 the pumps should be the same if it hits the cover you may not have the right pump. dont ya need a spacer thing to go between the pump an head Quote Link to comment
philip1 Posted September 17, 2008 Report Share Posted September 17, 2008 oops forgot about the spacer.... yah if thats not there the arm will hit Quote Link to comment
City Hunter Posted September 17, 2008 Author Report Share Posted September 17, 2008 yeah found the problem. The inline 4 l series spacers are different than the inline 6. There is a small portion that sticks up past the head I didnt notice. You are right though the eccentric is the same, but I grabbed a spare just in case. Thanks. Quote Link to comment
lynchfourtwenty Posted September 17, 2008 Report Share Posted September 17, 2008 np Quote Link to comment
