help sd22 transmission connection
Yedi
Ok i have a major problem somehow the pin that hooks the shifter onto the transmission is missing my family has been helping me with the restoration and had pulled motor and tranny there is a little pin with two c clips evidently that is missing now does anyone know where i can find this part to replace or if other models have the same size pin so i can search the bone yards praying
  • Replies 4
Is hole on one side half round-ish or both sides round.. If both sides round almost any rear wheel drive datsun earlier than 85 might work.. I say might as you would still have to check for yourself.
   My brother lost the pin for his 510 trans, and he drilled the holes out to closest  bolt size and used a nylock nut and bolt that has shoulder just wider that width of flanges. Still drives it like that to this day.
